What items should be prepared before the first flight of the DJI Mini 5 Pro?
Fórum DJI Mini 5 Pro Drone Everything you need to know about DJI Mini 5 Pro Drone
What items should be prepared before the first flight of the DJI Mini 5 Pro: Before the first flight, the DJI Mini 5 Pro requires thorough preparation to ensure safe and proper operation. The process begins by removing the storage cover that protects the gimbal and camera, as leaving it on during power-up can affect internal self-tests. Next, the battery must be activated by pressing the power button once to wake up the system, ensuring the aircraft recognizes the power supply correctly. Afterward, the drone's arms must be unfolded, following the order indicated in the manual, as this allows the internal sensors to detect their operational status before takeoff.
The DJI Mini 5 Pro incorporates an automatic power-on system that activates when unfolding the rear right arm. However, this feature can be disabled if using the USB-C port, as the wired connection temporarily suspends the automatic start-up. This means the user must ensure they disconnect any device from the port before attempting to power on the drone by folding it. If the battery does not take off after initial activation, it will re-enter sleep mode. You will need to press the power button or connect it to a charger to reactivate it.
DJI recommends using only official chargers for intelligent batteries, ensuring a balanced and stable charge. Furthermore, the ambient temperature must be within the range of -10°C to 40°C to avoid errors during calibration or possible damage to the electronic components. This thermal monitoring is essential, especially during the first few hours of flight, when the sensors and firmware are still undergoing full calibration.
Finally, it is advisable to perform a visual inspection of the drone, verifying that there is no physical damage to the propellers, arms, and sensors. Once these steps are completed, the DJI Mini 5 Pro will be ready to be powered on and subsequently paired with the remote controller, ensuring a safe and smooth start to the flight.
Volver a “Everything you need to know about the DJI Mini 5 Pro Drone fórum”
