How are firmware updates performed on the DJI Mini 5 Pro?
Fórum DJI Mini 5 Pro Drone Everything you need to know about DJI Mini 5 Pro Drone
How are firmware updates performed on the DJI Mini 5 Pro: The DJI Mini 5 Pro requires periodic firmware updates to improve performance, fix bugs, and add new features. Each time a version is released, the DJI Fly app automatically notifies the user upon powering on the drone and remote controller. From there, the pilot can begin downloading the update package, ensuring they have a stable Wi-Fi connection and at least 50% battery life on both devices before beginning the process.
During the update, the system will transfer the new firmware to the drone and controller components, including the gimbal, vision sensors, and GPS module. It is important not to turn off or disconnect any equipment while the update is in progress, as an interruption could cause system startup failures. The estimated update time is typically 10 to 15 minutes, depending on connection speed and file size.
Once the update is complete, the DJI Mini 5 Pro performs a self-test to confirm that all components have been configured correctly. If the process is successful, the app will display a confirmation notification and prompt you to restart the drone to apply the changes.
Consistently updating the firmware ensures that the DJI Mini 5 Pro maintains optimal performance, compatibility with the latest DJI Fly features, and increased safety during flight. Therefore, it is recommended to periodically check for new versions before each flight session.
Volver a “Everything you need to know about the DJI Mini 5 Pro Drone fórum”
