What limitations should be considered when using ActiveTrack on the DJI Mavic 4 Pro?
What limitations should be considered when using ActiveTrack on the DJI Mavic 4 Pro: Although the DJI Mavic 4 Pro's ActiveTrack is an advanced feature, it has limitations that must be taken into account. One of these is the maximum speed it can track. If the subject exceeds the 12 m/s limit, the system could lose the frame or stop recognizing it. This makes it less effective in sports or activities with very fast movement.
Another limitation is the complexity of the environment. Areas with branches, cables, or reflective surfaces can confuse the sensors, reducing tracking accuracy. Similarly, low-light conditions or monochromatic environments affect the drone's ability to correctly identify the subject.
Tracking can also be compromised if the subject is hidden for an extended period of time behind large obstacles, as the system relies on continuous visibility to maintain accuracy.
Ultimately, although ActiveTrack offers impressive results, it is essential to evaluate the environmental conditions and subject characteristics before using it to ensure optimal and safe performance.
