What precautions does the DJI Mavic 4 Pro recommend when setting up routes in Waypoint Flight?
What precautions does the DJI Mavic 4 Pro recommend when setting up routes in Waypoint Flight: The DJI Mavic 4 Pro recommends carefully planning the height of each waypoint to avoid obstacles. Although the sensors provide additional safety, initial programming is essential to prevent incidents. The safety margin must be sufficient in environments with trees, poles, or buildings.
It is also essential to ensure that the route is developed in an area with a stable GNSS signal, as the accuracy of Waypoint Flight directly depends on the quality of the satellite connection. Flying in areas with magnetic interference or signal limitations can compromise the route.
The pilot should check the battery level before executing the mission, calculating whether it is sufficient to complete the route and safely return to the starting point. Additionally, it is recommended to always monitor the flight in real time to react in case of unforeseen events.
In short, the precautions in Waypoint Flight ensure that the DJI Mavic 4 Pro executes long trajectories efficiently, reducing risks and delivering consistent results in highly demanding projects.
