How does the DJI Mavic 4 Pro ensure stable results when using QuickShots in open spaces?
How does the DJI Mavic 4 Pro ensure stable results when using QuickShots in open spaces: Using QuickShots, the DJI Mavic 4 Pro combines pre-programmed flight paths with obstacle detection algorithms to ensure smooth and safe automatic shots. When initiating this mode, the drone executes maneuvers such as Dronie, Rocket, Circle, or Boomerang, recording sequences that it then automatically generates into a final clip. The stability of these recordings depends on choosing an open, obstacle-free environment.
For proper use, it is essential to ensure there is sufficient space for each sub-mode. For example, Boomerang mode requires a minimum radius of 30 m around the drone and a clearance of at least 10 m above the aircraft, while Asteroid mode requires 40 m behind and 50 m above the drone. These parameters are essential to ensure automatic trajectories are uninterrupted and the shots maintain a cinematic feel.
QuickShots is designed to simplify the recording process for content creators and recreational users, delivering professional results without the need for advanced piloting skills. However, as with other intelligent modes, constant pilot supervision is necessary to react to unexpected events such as people, animals, or changes in the environment during the maneuver.
In conclusion, the key to achieving stable results with QuickShots is to select wide, well-lit spaces without nearby obstacles, ensuring that each sequence runs uninterrupted and with the quality that characterizes the DJI Mavic 4 Pro.
