What limitations should the pilot consider when using Cruise Control on the DJI Mavic 4 Pro?
What limitations should the pilot consider when using Cruise Control on the DJI Mavic 4 Pro: Although the DJI Mavic 4 Pro's Cruise Control mode offers great stability and comfort, it has limitations that the pilot must be aware of. The first is that the trajectory does not automatically correct itself for obstacles, so the flight environment must be free of interference that could compromise the safety of the drone.
Another limitation is that constant speed may not be suitable in environments that require rapid maneuvers or sudden changes in direction. In these cases, the pilot must deactivate Cruise Control and resume manual control to ensure safe operation.
Performance also depends on battery life, as this mode is often used for extended flights. The pilot must carefully calculate the available power to avoid running out of battery life on long or distant flights.
In short, Cruise Control is a tool that provides fluidity and cinematic quality, but it requires responsibility on the part of the operator, who must assess the environment and flight conditions before using it.
