What precautions does the DJI Mavic 4 Pro recommend when using TapFly in tight spaces?
What precautions does the DJI Mavic 4 Pro recommend when using TapFly in tight spaces:
The DJI Mavic 4 Pro recommends using TapFly only in environments with sufficient space free of obstacles, as the aircraft will follow the path marked on the screen without stopping until commanded by the pilot. While obstacle detection sensors help prevent collisions, maneuverability may be limited in tight spaces.
It is essential to maintain line of sight to the drone throughout the TapFly flight, as this mode could pass through areas with trees, poles, or structures if not properly monitored. Additionally, the pilot must always be ready to cancel the automatic path and resume manual control in case of risk.
Another important consideration is lighting. TapFly relies on visual sensors to maintain stability, and in low-light conditions or on reflective surfaces, accuracy may be compromised. Therefore, using this mode indoors or at night is not recommended.
In conclusion, TapFly is a very useful resource for straight trajectories, but it requires careful planning and clear environments to ensure the safety of the drone and the quality of the recorded footage.
