What benefits does the DJI Mavic 4 Pro offer when using the Obstacle Sensing System in automatic flights?
What benefits does the DJI Mavic 4 Pro offer when using the Obstacle Sensing System in automatic flights: The DJI Mavic 4 Pro's Obstacle Sensing System provides an advanced level of safety in automatic flights, allowing the drone to identify and avoid objects in its path without manual intervention. During pre-programmed trajectories, such as Waypoints or Points of Interest, the drone analyzes the environment in real time using cameras and sensors distributed in multiple directions, adjusting its flight to avoid potential collisions. This technology gives the pilot confidence that the aircraft can operate more safely in complex environments.
A key advantage is the system's ability to maintain the flow of footage even when encountering obstacles. Instead of abruptly stopping, the DJI Mavic 4 Pro can circle the object and continue on the planned path, achieving smoother, more professional footage. This is especially useful in audiovisual productions, where an interruption could ruin the shot.
The system is also essential in inspection or mapping flights, where route accuracy is crucial. By avoiding collisions with structures such as poles, cables, or buildings, the drone maintains its physical integrity and protects the operator's investment. Furthermore, the combination of artificial intelligence and obstacle detection improves efficiency by reducing the need for constant corrections by the pilot.
Finally, the use of the system in automatic flights makes the DJI Mavic 4 Pro an accessible tool for less experienced operators. Active sensor assistance reduces the learning curve and makes it easier for any user to perform advanced flights with greater safety.
