What safety precautions do you recommend following when launching the DJI Mavic 4 Pro in confined spaces?
What safety precautions do you recommend following when launching the DJI Mavic 4 Pro in confined spaces: When launching the DJI Mavic 4 Pro in confined spaces, it is essential to ensure that the area is completely free of obstacles, both on the ground and in the surrounding area. The propellers need adequate space to spin without the risk of hitting walls, ceilings, or nearby objects that could cause an accident. Additionally, it is recommended to use propeller guards to minimize damage in the event of accidental contact with surfaces. Properly preparing the launch site is key to avoiding incidents from the first second of flight.
Another important aspect is that, in confined spaces, the GPS may not function properly due to satellite signal obstruction. Under these conditions, the drone enters ATTI mode and will not be able to remain stationary on its own. This means that the pilot must be experienced enough to manually control the drone, compensating for displacements caused by air currents or the effect of its own propulsion. Practicing in open areas is recommended before attempting flights in confined environments.
It's also advisable to set height and distance limits within the DJI Fly app before takeoff. These settings help ensure the drone doesn't exceed the limits of the available space, reducing the risk of colliding with ceilings or walls. The calibration of the vision and obstacle sensors should be checked, as they play a vital role in avoiding collisions when space is very tight.
Finally, the pilot must always maintain direct view of the drone and be prepared for an immediate landing in the event of a loss of control. Having a flat, firm, and clear landing surface is crucial in small spaces. These precautions, combined with the operator's experience, allow the DJI Mavic 4 Pro to take full advantage of its capabilities without compromising safety.
