How many types of Return to Home does the Mavic 4 Pro have?
How many types of Return to Home does the Mavic 4 Pro have: The DJI Mavic 4 Pro has three main types of Return to Home: Smart RTH, Low Battery RTH, and Signal Loss RTH. Smart RTH is activated manually from the app or remote controller when the pilot decides the drone should return to the home point. Low Battery RTH is activated automatically when the system calculates that the remaining power is sufficient for a safe return. Signal Loss RTH is activated when the drone loses communication with the controller for a specified period of time.
With Smart RTH, the pilot has full control over the activation timing and can do so at any point during the flight. This is useful for saving battery life or avoiding sudden weather hazards. Low Battery RTH is preemptive and activated automatically; however, the pilot can choose to land in a closer location if it is deemed safer.
With Signal Loss RTH, the drone will attempt to reestablish connection for a few seconds before initiating the return. This process is critical to preventing the drone from wandering off uncontrollably and ensuring it returns to a safe route. If the signal is reestablished, the pilot can cancel RTH and continue the flight normally.
The ability to choose between different types of RTH provides the Mavic 4 Pro with extremely flexible response to unexpected situations. This significantly reduces the chances of losing the drone and protects the user's investment on high-risk or long-distance flights.
