How do I properly record the home point on the Mavic 4 Pro: Recording the home point on the DJI Mavic 4 Pro is an automatic process that occurs once the drone acquires sufficient satellite signal and confirms its GPS position. This point is used as a reference for the return-to-home function, so its accuracy is critical for a safe landing in the event of an emergency or loss of signal. Recording confirmation usually appears in the DJI Fly app with a visual message and, in many cases, also with a voice prompt on compatible controllers.
To ensure the home point is recorded correctly, it is important to take off from a location with good visibility to the sky, free of obstacles such as buildings, trees, or metal structures that could block the signal. If the drone is turned on in an environment with interference, the recorded point may not be exact, which could compromise the automatic return. The process usually completes within a few seconds, but in new locations or under adverse weather conditions, it may take longer.
It's possible to update the home point during the flight if the operator changes position or if a new waypoint is desired. This is useful during moving flights, such as from a vehicle or boat, where the original location may become obsolete. To do so, simply access the DJI Fly app's options and select the option to update the home point to the current location of the drone or remote controller, as appropriate.
Correctly recording the home point not only optimizes safety but also improves the pilot's confidence, knowing that if RTH is activated, the drone will take the safest route to return to a previously defined location. This procedure should be part of the pre-flight checklist, and its correct execution can make the difference between recovering the equipment or losing it.
How do I properly record the home point on the Mavic 4 Pro?
Ir a
- Drone forum in English
- ↳ DJI brand drone forum
- ↳ Preséntate al foro :)
- ↳ Te ayudamos con tu drone
- ↳ Comunidad del drone DJI
- ↳ Comunidad del drone FAYEE
- ↳ Comunidad del drone FQ777
- ↳ Comunidad del drone JJRC
- ↳ Comunidad del drone JXD
- ↳ Comunidad del drone MJX
- ↳ Comunidad del drone Syma
- ↳ Comunidad del drone VISUO
- ↳ Drones Fuera de Lista
- Zona Taller y Complementos
- ↳ Sección de Complementos
- ↳ Baterías y Cargadores
- ↳ Controladoras de Vuelo
- ↳ ESC´s o Variadores
- ↳ Hélices
- ↳ Motores de Drones
- ↳ Mandos o Control Remotos
- ↳ Foro sobre Betaflight
- ↳ Foro Insta360 Ace Pro 2
- ↳ Foro GoPro HERO 13 Black
- ↳ Foro Drones Argentina
- ↳ Foro Drones Bolivia
- ↳ Foro Drones Chile
- ↳ Foro Drones Colombia
- ↳ Foro Drones Costa Rica
- ↳ Foro Drones Cuba
- ↳ Foro Drones Ecuador
- ↳ Foro Drones España
- ↳ Foro Drones Guatemala
- ↳ Foro Drones Honduras
- ↳ Foro Drones México
- ↳ Foro Drones Panamá
- ↳ Foro Drones Perú
- ↳ Foro Drones Uruguay
- ↳ Foro Drones Venezuela
