How do I properly turn on the DJI Mavic 4 Pro for the first time?
How do I properly turn on the DJI Mavic 4 Pro for the first time: Turning on the DJI Mavic 4 Pro for the first time requires following a precise sequence that ensures both user safety and proper system initialization. First, make sure both the drone and remote controller batteries are fully charged, using only official chargers supplied by DJI. A partially charged battery can affect performance during startup, especially during initial setup, when automatic firmware updates may occur.
To turn on the drone, briefly press the power button on top of the Mavic 4 Pro's intelligent battery once, then hold the same button for approximately two seconds until the LED indicators light up. This procedure is standard on most DJI devices and prevents the drone from being accidentally activated by an inadvertent press. Once powered on, the system performs an automatic status check (self-diagnosis) that includes checking the sensors, motors, GPS navigation system, and battery.
At the same time, turn on the DJI RC Pro remote controller (or other compatible controller) by pressing its power button in the same way: a short press followed by a long press. When you turn on both devices, an automatic connection is established between the drone and the controller, provided they have been previously paired. If this is your first time, you may need to pair manually, following the on-screen instructions in the DJI Fly app. At this point, the interface will ask you to update the firmware, register the device, and complete the basic flight settings.
