What risks are involved in flying the Mavic 4 Pro over bodies of water and how can they be reduced?
What risks are involved in flying the Mavic 4 Pro over bodies of water and how can they be reduced: Operating the DJI Mavic 4 Pro over bodies of water such as lakes, rivers, or the ocean presents additional challenges that must be carefully considered. One of the main risks is that, in the event of a motor, battery, or signal failure, the drone will not be able to land safely and will be completely lost upon landing in the water. Unlike solid ground, water makes it impossible to recover the aircraft, and the electronic components are not designed to withstand immersion.
Another significant risk is associated with altitude readings. The drone's lower visual sensors may have difficulty detecting the water surface correctly, especially if it is very clear or has strong reflections from sunlight. This can cause errors in the altitude maintained, which in some cases result in abrupt descents or collisions with the water surface.
To mitigate these hazards, it is recommended to maintain a minimum safe altitude of at least 5 meters above the water level. Furthermore, it is advisable to avoid flights over water in windy conditions, as sun glare and the lack of visual references can make manual control and visual navigation difficult. Pre-planning your flight, using cine mode for smooth flights, and always maintaining eye contact are key actions.
In short, while flying over water allows for spectacular shots, it carries specific risks that require extra caution. Prioritizing flight safety and being mindful of the limitations of the aquatic environment is essential to avoid costly and irreversible losses.
