What protocol should be followed if the DJI Mavic 4 Pro suffers a minor collision during flight?
What protocol should be followed if the DJI Mavic 4 Pro suffers a minor collision during flight: If the DJI Mavic 4 Pro suffers a minor collision during flight, the first step should be to assess whether the drone is still responding to controls. If it remains stable, land it immediately in a safe area for a detailed inspection. If the drone loses altitude or exhibits unusual behavior such as vibrations, jerky movements, or loss of video signal, engage RTH if safe, or take manual control to slowly steer it toward the nearest landing point.
Once on the ground, it is essential to check the condition of the propellers, as they may have suffered damage that is invisible to the naked eye. A slightly deformed propeller can cause vibrations that affect flight stability and gimbal performance. The drone's chassis should also be inspected for cracks, fissures, or loose parts, as well as the operation of the motors, which should rotate smoothly and without abnormal noises. If damage is detected in any of these components, the flight should be suspended until a proper repair can be performed.
The gimbal and camera should also be carefully inspected. If there are signs of misalignment or limited movement, it may be displaced from the axis or an internal connector may have come loose. In this case, recalibrating the gimbal from the app may resolve the issue, but if the anomaly persists, it is best to take the equipment to an authorized DJI service center. It is also recommended to check that the sensors are not obstructed by dirt or small debris from the collision.
Recording the event in the DJI Fly app and saving the flight log helps identify exactly what happened before the impact. If the incident recurs or if the system shows continuous calibration errors, the collision may have caused a deeper misconfiguration. When in doubt, halting operations and performing full maintenance is always the best decision to preserve the integrity of the DJI Mavic 4 Pro and ensure future missions without incident.
