What precautions should be taken when flying the DJI Mavic 4 Pro at night or in low-light conditions?
What precautions should be taken when flying the DJI Mavic 4 Pro at night or in low-light conditions: Flying the DJI Mavic 4 Pro in low-light conditions or at night requires special preparation and caution due to limitations in visual perception of the surroundings and the reduced performance of certain sensors. Although the drone is equipped with navigation lights and advanced visual sensors, the latter can become less effective in the dark, forcing the system to rely almost exclusively on GNSS satellite positioning. Therefore, one of the first steps before beginning a night flight is to verify that the GPS signal is strong and stable.
In addition, it is recommended to keep the drone within a close radius and avoid complex maneuvers, as obstacles can be more difficult to detect visually. The drone's lights help locate it, but they do not sufficiently illuminate the surroundings to detect cables, branches, or other potentially dangerous elements. Therefore, the flight environment should be assessed beforehand during the day to identify potential risks. It is also advisable to fly at a constant altitude and avoid sudden changes in direction or height.
In many countries, night flights are regulated and may require special permits. Even if not mandatory, it is good practice to notify local authorities or other people in the area of ​​the activity to avoid misunderstandings or unnecessary reports. In professional flights, it is common to use additional strobe lights or reflectors mounted on the drone to increase visibility, although this can affect weight and range, so it should be carefully considered.
The key to safe night flights is preparation and caution. Having a well-defined route, flying at low speeds, constantly monitoring telemetry in the app, and being prepared to activate automatic return (RTH) in case of disorientation are essential measures. With these precautions, the DJI Mavic 4 Pro can operate successfully in low-light environments, allowing you to capture unique and spectacular shots without compromising safety.
