What is the maximum transmission range of the DJI Mavic 4 Pro under ideal transmission conditions?
What is the maximum transmission range of the DJI Mavic 4 Pro under ideal transmission conditions: The DJI Mavic 4 Pro is designed to offer an impressive transmission range thanks to OcuSync 4.0 technology, which provides a stable, low-latency connection between the drone and the remote controller. Under ideal conditions—without electromagnetic interference and with direct line of sight—the drone can operate up to 20 kilometers (12.2 miles) in compliance with FCC standards. This capability makes it a powerful tool for long-range missions, both in professional operations and for exploring vast terrain.
This transmission range is relevant not only for the physical distance the drone can travel, but also for the continuous quality of the video signal transmitted in real time to the operator. Unlike previous models, the Mavic 4 Pro can send a video stream of up to 1080p in high definition over long distances, allowing for a more immersive and safer flight experience. This capability is crucial for applications in mapping, industrial inspection, or filmmaking where detail and visual fidelity are paramount.
To ensure this performance, it is recommended to operate the drone in open areas, away from sources of interference such as pylons, high-rise buildings, or areas with high Wi-Fi signals. It is also important to keep the drone within line of sight at all times, even at a technically great distance, to comply with local regulations and avoid unexpected accidents. Furthermore, the remote controller antennas must be properly oriented according to the manufacturer's instructions to maximize signal reception.
It is essential to note that the maximum range can vary significantly depending on the environment and local regulations. For example, in regions with CE regulations, the range may be reduced to 10 or even 8 kilometers due to power emission limitations. Therefore, although the Mavic 4 Pro offers great technical potential, the operator must always plan flights within a safe margin, taking into account legal and technical factors to ensure successful and uninterrupted flights.
