What flight environment precautions does DJI recommend for safely operating the Mavic 4 Pro?
What flight environment precautions does DJI recommend for safely operating the Mavic 4 Pro: DJI establishes a series of specific environmental recommendations that every pilot must follow to ensure safe flight with the Mavic 4 Pro. First, flying in adverse weather conditions such as rain, snow, thick fog, or strong wind is strictly prohibited. These conditions not only make the drone difficult to control, but can also damage electronic systems, affect the GNSS signal, and impair visual navigation sensors, thus compromising flight safety.
Another important consideration is the choice of takeoff and operating location. DJI recommends flying in open areas, away from tall buildings, metal towers, or base stations that may interfere with the electronic compass or GPS signal. Additionally, the drone must always remain within the pilot's line of sight (VLOS). In automatic flights or return-to-home (RTH), if the point of home was not correctly established due to urban interference, the pilot must cancel the automatic return and land manually to avoid navigation errors.
Electromagnetic interference also poses a significant risk. Areas near high-voltage power lines, transmission stations, or electrical substations should be completely avoided. Likewise, flying at extreme altitudes is advised against due to variations in air pressure and the limited response of the motors and batteries. DJI even indicates that the GNSS system may not function properly in polar regions, so in these cases, vision-based navigation should be used exclusively.
Applying these precautions not only extends the lifespan of the DJI Mavic 4 Pro, but also prevents incidents and legal penalties, ensuring smooth, stable, and precise flights in any environment. Proper environmental preparation is, therefore, an inseparable part of a professional, responsible operation aligned with the highest aviation safety standards.
