What recording format and resolution options are available on the DJI Mavic 4 Pro?
What recording format and resolution options are available on the DJI Mavic 4 Pro: The DJI Mavic 4 Pro offers an impressive variety of recording formats and resolutions, designed to satisfy both casual content creators and video professionals. Available resolutions include 5.1K at 60 fps, 4K at 120 fps, and 1080p at up to 200 fps, allowing you to capture everything from standard shots to high-quality slow-motion sequences. This versatility allows the drone to be adapted to different types of projects, from social media content to high-end audiovisual productions.
In terms of formats, the Mavic 4 Pro supports recording in H.264 and H.265, both highly compatible with current editing programs and offering different levels of compression and quality depending on the user's needs. Additionally, the drone can record in Apple ProRes (on certain model versions), ideal for users seeking maximum image fidelity and a professional workflow compatible with film industry standards. This level of quality is especially appreciated in commercial productions, documentaries, and even independent films.
The system also allows for the selection of advanced color profiles such as D-Log M or HLG, which provide greater editing latitude in post-production. D-Log M, for example, is designed to retain the widest possible dynamic range, which is essential for those who want to apply detailed color correction without losing quality. HLG (Hybrid Log Gamma) is geared toward HDR playback on compatible televisions, making it ideal for content intended for platforms like YouTube or Netflix.
To maximize performance in each format, it is recommended to use high-speed microSD cards rated V30 or higher, and ensure the firmware is updated to access the latest codecs and stability improvements. The Mavic 4 Pro's wide range of formats and resolutions makes this drone a reference tool for those seeking flexibility, power, and professional quality in a single device.
