What white balance control options does the DJI Mavic 4 Pro camera offer?
What white balance control options does the DJI Mavic 4 Pro camera offer: The DJI Mavic 4 Pro allows the user to adjust the white balance manually or automatically, depending on the lighting conditions and the type of content being captured. In automatic mode, the system analyzes the scene in real time to determine the most appropriate color temperature, which is useful in changing lighting environments, such as partly cloudy days or mixed-light interiors. However, this option can produce unwanted variations if the lighting changes abruptly during recording.
In manual mode, the operator can select specific Kelvin temperature values, such as 3200K for warm lighting or 5600K for daylight, ensuring color consistency in continuous shots. This option is especially valuable when filming for professional productions, as it prevents the color jumps that often complicate post-production. For example, when shooting an outdoor scene at sunset, setting the balance to 5200K helps maintain a consistent warm tone without relying on the drone's automatic interpretation.
The Mavic 4 Pro camera also allows you to save custom white balance settings for recurring use. This saves time on repetitive productions and ensures a consistent look between flights. Additionally, these settings can be combined with color profiles like D-Log M for more natural and controllable results in editing.
In conclusion, white balance on the Mavic 4 Pro is a powerful tool for maintaining the color fidelity of your content. Whether used in automatic mode for simplicity or in manual mode for maximum precision, knowing and correctly applying this feature can make the difference between a professional image and one with unsightly color casts.
