Does the DJI Mavic 4 Pro allow slow motion recording, and in what resolutions is it possible?
Does the DJI Mavic 4 Pro allow slow motion recording, and in what resolutions is it possible: Yes, the DJI Mavic 4 Pro allows slow motion recording, a feature highly valued by content creators who want to capture movements with a high level of detail. The slow motion function is available thanks to its ability to record at high frames per second, especially in resolutions such as Full HD (1920x1080p), where it can reach up to 240 fps, allowing playback at a quarter of the original speed when viewed at 60 fps. This mode is ideal for recording sports action, wildlife, or events where speed is critical to the visual narrative.
To take advantage of this capability, it is essential to properly configure the camera from the drone's settings menu. Once you choose 1080p resolution, the higher frame rate options are enabled, and you can select the most appropriate one based on your creative intent. For example, 120 fps can be used for smooth slow motion, while 240 fps offers more dramatic effects. Furthermore, image quality remains excellent thanks to the large main sensor and its color processing.
It's also important to consider the recording environment. For optimal slow motion results, it's recommended to shoot in well-lit conditions, as the higher shutter speeds required for these modes can result in dark images in dimly lit environments. ND filters can also be useful for controlling exposure, especially in sunny exteriors.
Finally, slow motion processing can be done directly in post-production using software such as Final Cut, Premiere Pro, or DaVinci Resolve, or take advantage of DJI Fly's own features for quick and convenient editing. The flexibility offered by the DJI Mavic 4 Pro in this regard makes it an advanced tool for both professionals and creative video enthusiasts.
