Which microSD cards are compatible with the DJI Mavic 4 Pro and what is the maximum capacity?
Which microSD cards are compatible with the DJI Mavic 4 Pro and what is the maximum capacity: The DJI Mavic 4 Pro supports high-speed microSD cards up to 512GB, allowing users to store large amounts of video in 4K or higher resolutions without having to change cards frequently. DJI recommends using UHS-I or UHS-III microSD cards with a speed class of V30 or higher to ensure stable writing during high-bitrate video recording, such as H.265 and Apple ProRes.
Choosing the correct card is critical to avoid write errors, file loss, or failure to start recording. For example, if you use a card that doesn't meet the minimum speed, the system may automatically stop recording or display error messages. Recommended cards include the SanDisk Extreme Pro, Lexar 1066x, or the Samsung EVO Plus, all in 128GB, 256GB, or 512GB versions. These models are tested by DJI and offer consistent performance even during extended recording sessions.
Additionally, the Mavic 4 Pro features internal storage that acts as a backup if a card is not inserted or fails. However, this built-in memory has limited capacity, so it is no substitute for a high-capacity card for professional operations. It is also possible to directly export content via the drone's USB-C port or wirelessly connect to a mobile device using QuickTransfer.
For tasks such as inspections, long recordings, or automated flights where changing cards mid-process is impractical, having a high-capacity, high-speed microSD card is essential. This not only allows for uninterrupted capture of footage but also reduces subsequent download time, improving the efficiency of the entire aerial operation.
