What is the estimated charging time for the DJI Mavic 4 Pro battery and which charger is recommended?
What is the estimated charging time for the DJI Mavic 4 Pro battery and which charger is recommended: The DJI Mavic 4 Pro battery charging time may vary depending on the charger used, environmental conditions, and battery condition. Under optimal conditions and using the official DJI charger with PD fast charging support, the estimated time for a full charge of the standard battery (5000mAh 4S Li-ion type) ranges between 70 and 90 minutes. This allows users to minimize downtime between flights, which is especially useful in professional settings where every minute counts.
It is essential to use a DJI-certified charger or one that supports the USB Power Delivery (PD) protocol at 65W or higher. Using generic, low-power or uncertified chargers can significantly lengthen charging times or even cause irreversible damage to the battery. Some third-party chargers offer multiple outputs and may seem convenient, but if they don't guarantee protection against overheating and overcharging, they pose a significant risk to the drone's integrity.
Another important consideration is the ambient temperature during charging. DJI recommends charging in a well-ventilated environment, between 5 and 40°C (41 and 104°F), as temperatures outside this range can slow down the process or even stop it for safety reasons. It's also advisable to wait a few minutes after the flight before starting to recharge, as batteries tend to heat up during intensive use and must return to a safe temperature to begin the charging process.
Finally, for users operating with multiple batteries, using DJI's Intelligent Charging Hub can optimize overall recharging time, as the system automatically prioritizes the battery with the highest charge level to accelerate the drone's availability. This feature, combined with Intelligent Power Distribution technology, makes the Mavic 4 Pro an efficient tool for continuous and extended field operations.
