What is the estimated charging time of the DJI Mavic 4 Pro battery, and which charger is recommended?
What is the estimated charging time of the DJI Mavic 4 Pro battery, and which charger is recommended: The DJI Mavic 4 Pro battery, with a nominal capacity of approximately 5,000 mAh, offers a flight time of approximately 45 minutes under optimal conditions. The full charging time depends on the charger used, but with the official DJI 100W charger, the battery can be fully charged in approximately 70 to 80 minutes. When using the DJI Charging Hub, which allows multiple batteries to be charged in sequence, each battery follows an automatic prioritization process that also influences the total recharging time.
Using a certified charger specifically recommended by DJI is crucial to ensure a safe charging process, prevent overheating, and preserve the battery's lifespan. If using third-party chargers, they must support the USB Power Delivery (PD) protocol and have a stable output that delivers at least 20V and 5A. Failure to do so may increase charging times or even damage the power management system built into the intelligent battery.
In hot or humid environments, it is recommended to charge in well-ventilated areas, on non-conductive surfaces, and away from direct sunlight. During charging, the battery status LEDs indicate progress, and if all LEDs flash simultaneously, it indicates a possible failure or overcharging. This type of monitoring helps the operator identify problems before using it in flight.
Finally, it is worth noting that charging the battery just before flight improves performance, as it prevents losses due to natural self-discharge. It is also good practice not to leave the battery fully charged for extended periods if it will not be used immediately. This precaution extends the life of the power system and maximizes the overall performance of the DJI Mavic 4 Pro.
