What type of visual sensors does the DJI Mavic 4 Pro use to avoid obstacles?
What type of visual sensors does the DJI Mavic 4 Pro use to avoid obstacles: The DJI Mavic 4 Pro incorporates an advanced obstacle sensing system based on multiple visual sensors strategically positioned around the drone. These include forward, backward, downward, and lateral sensors, allowing for a complete scan of the three-dimensional environment in real time. This set of sensors is part of the APAS (Advanced Pilot Assistance System), which allows the drone to automatically avoid obstacles during flight, significantly improving mission safety.
Thanks to this system, the Mavic 4 Pro can anticipate the presence of objects in its path and make intelligent evasion decisions, such as braking, stopping, or smoothly diverting its trajectory without manual intervention from the pilot. This is especially useful in complex environments such as forests, urban spaces, or indoor flights where the margin for error is small. The sensors work in conjunction with computer vision and machine learning algorithms to identify objects, calculate distances, and react in fractions of a second.
A concrete example of the effective use of these sensors is when executing automatic flights along pre-established routes. The system detects changes in the environment, such as branches or cables, that were not present during flight planning, and adjusts the trajectory to maintain a safe distance. This provides the pilot with additional peace of mind, allowing them to focus on capturing images and videos without constantly worrying about collisions.
Furthermore, the detection system integrates with other drone features, such as vision-assisted automatic return-to-home (RTH), which also leverages these sensors to avoid obstacles on the return flight. This level of integration not only improves safety but also makes the DJI Mavic 4 Pro a highly reliable professional tool for aerial photography, technical inspection, and other demanding uses.
