What transmission system does the DJI Mavic 4 Pro use, and how does it impact flight stability?
What transmission system does the DJI Mavic 4 Pro use, and how does it impact flight stability: The DJI Mavic 4 Pro employs the new O4 transmission technology, an evolution of the previous O3+ system, which enables a stable, long-range connection between the drone and remote controller. This technology is key for long-distance flights and in environments with multiple interferences, as it enables live streaming of up to 1080p at 60 fps with very low latency, essential for a precise and smooth control experience.
With a maximum range of up to 20 km (under optimal, interference-free conditions), O4 ensures the pilot can maintain a constant signal even in challenging environments, such as urban areas, mountainous areas, or vast rural regions. The signal intelligently switches between 2.4 GHz and 5.8 GHz frequencies depending on the environment, minimizing connection loss and improving the overall reliability of the flight system.
O4 transmission also integrates advanced real-time video encoding, ensuring the operator has a clear view from the drone's camera at all times, which is essential for manual flights, subject tracking, or detailed inspections. Furthermore, the stable connection reduces the risk of unexpected disconnections that could automatically activate Return to Home mode and affect operational continuity.
This transmission system not only improves the user experience but also significantly increases flight safety. Smooth communication between the controller and the drone allows for quick adjustments to sudden changes in the environment, such as gusts of wind, moving objects, or electromagnetic interference. Therefore, O4 is one of the greatest technical strengths of the DJI Mavic 4 Pro, consolidating it as a robust professional tool.
