What is the DJI Mavic 4 Pro's positioning accuracy when flying in hover mode?
What is the DJI Mavic 4 Pro's positioning accuracy when flying in hover mode: The DJI Mavic 4 Pro offers extremely high positioning accuracy when flying in hover mode, both indoors and outdoors. Thanks to the combination of its multi-band GNSS system (GPS, Galileo, BeiDou, GLONASS) and advanced downward-facing and multi-directional vision sensors, the drone can maintain a near-stationary position in the air, with minimal deviations of just centimeters in ideal conditions. This allows for precisely framed photos and videos without unwanted movement, even in tight spaces or where a high degree of precision is required.
When flying outdoors with a stable GNSS signal, the Mavic 4 Pro can maintain a hover position with a horizontal accuracy of ±0.1 meters and a vertical accuracy of ±0.3 meters. This capability is essential for technical inspection tasks, static photography, or close-range flights of delicate structures, as it ensures that the drone does not drift from its programmed location. This precision also improves the experience in pre-programmed automatic flights, where waypoints must be executed with millimeter accuracy.
In interiors or areas with limited satellite signal, the drone activates its visual positioning system assisted by infrared and downward-looking sensors. This combination allows it to detect patterns on the ground and measure distance with great accuracy, allowing it to maintain stability even at low altitudes or on smooth surfaces. To achieve maximum effectiveness in these conditions, good ambient lighting is recommended, as is avoiding homogeneous or reflective surfaces that hinder visual detection.
Hovering precision not only improves the quality of the captured content but also provides safety and confidence for the operator. Having a drone that stays firmly in place during variable conditions is a clear competitive advantage in professional use. Whether you're shooting a cinematic scene, inspecting a facade, or capturing photogrammetry, the Mavic 4 Pro offers the precision needed to complete the task with quality and safety.
