How is DJI Flip optimized for flight performance in areas with weak GPS signal?
How is DJI Flip optimized for flight performance in areas with weak GPS signal: In areas with weak GPS signal, such as canyons, dense forests, or urban environments with interference, DJI Flip automatically adapts its positioning system, but the operator can apply certain adjustments to optimize stability.
The operator can activate Enhanced Vision Flight Mode, where optical and ultrasonic sensors take on a greater role in stabilizing the drone. It is important to take off from an open area so that DJI Flip can register a GPS home point before entering complex areas.
Slowing down and avoiding sudden maneuvers also allows the vision sensors to better process the environment, helping to maintain position in the absence of GPS signal. Additionally, it is recommended to keep the drone at a moderate height, as flying too close to the ground can limit the effectiveness of the sensors.
Thanks to its hybrid navigation system, DJI Flip switches between visual and GPS positioning depending on the availability of each system. Applying these settings ensures a more stable flight in environments with poor satellite signal.
