How does compass calibration affect DJI Flip stability and when should it be done?
How does compass calibration affect DJI Flip stability and when should it be done: Compass calibration on DJI Flip is critical to ensuring accurate navigation, as this sensor allows the drone to correctly orient itself in relation to the Earth's magnetic field. An error in calibration can result in deviations in trajectory or difficulty maintaining a stable position.
It is recommended to calibrate the compass before each flight if the drone has been moved to a remote location or if electromagnetic interference is detected in the flight area. To do so, the operator must access the DJI Fly app and follow the instructions to perform the calibration process correctly.
Interference from metal structures, communication antennas, or power lines can affect the accuracy of the compass, which could lead the drone to make erratic movements. In these cases, it is recommended to change location and recalibrate before taking off.
Thanks to its advanced navigation system, DJI Flip alerts the operator if the compass needs to be calibrated. Performing this procedure regularly ensures safer flights and reduces the risk of orientation problems in the air.
