How do I use the DJI Flip's progressive ascent and descent mode to improve stability?
How do I use the DJI Flip's progressive ascent and descent mode to improve stability: The progressive ascent and descent mode on the DJI Flip allows the drone to ascend or descend in a controlled manner, avoiding sudden changes in altitude that can affect flight stability or cause unstable footage in recordings.
To activate this feature, the operator must adjust the sensitivity of the controls in the DJI Fly app and select a moderate ascent or descent speed. This ensures that the drone maintains a smooth transition without affecting its position in the air.
This mode is especially useful when flying in tight spaces or in environments with obstacles, where a sudden change in altitude could create an impact with the surroundings. It is also key in aerial filming, as it allows you to capture fluid camera movements without abrupt interruptions.
Thanks to its advanced stabilization system, the DJI Flip maintains precise control in ascent and descent, even in windy conditions. Using this feature improves flight safety and allows for more precise maneuvers in any scenario.
