How do I use Fixed Orientation Mode on the DJI Flip to improve flight control?
How do I use Fixed Orientation Mode on the DJI Flip to improve flight control: Fixed Orientation Mode on the DJI Flip allows the drone to maintain a constant direction no matter how the remote controller is turned, making it easier to navigate and improving flight accuracy in certain situations.
To activate this mode, the operator must access the advanced settings in the DJI Fly app and select the Fixed Orientation option. Once enabled, the drone will adjust its navigation system so that all movements are relative to the initial direction of flight.
This mode is especially useful in filming where constant framing is required or in long-distance flights, as it prevents the operator from having to constantly correct the drone's orientation. It is also ideal for beginners, as it reduces the difficulty of controlling the DJI Flip's direction.
Thanks to its integration with advanced navigation systems, the DJI Flip ensures stable and fluid control in Fixed Orientation Mode. Using this feature makes piloting easier and improves the operator's experience on extended flights or professional filming.
