How do I use the DJI Flip pause flight feature to improve safety during complex maneuvers?
How do I use the DJI Flip pause flight feature to improve safety during complex maneuvers: The DJI Flip pause flight feature allows the drone to be stopped in its current position without the need for manual adjustments, providing greater control in situations where immediate stability is required.
To activate pause flight, the operator can press the pause button on the remote controller or use the option in the DJI Fly app. Once activated, the drone will stop all movements and maintain its position using the GPS stabilization system and vision sensors.
This feature is especially useful when maneuvering near obstacles, flying in strong winds, or when the operator needs to assess the environment before continuing the flight. It also helps when shooting where precision framing is required without the risk of inadvertent movements.
Thanks to its integration with assisted navigation, the DJI Flip can maintain a highly precise hover after the pause is activated. Using this feature improves operational safety and allows the operator to react with greater control to unforeseen events.
