How is video transmission optimized on DJI Flip to avoid interference and signal loss?
How is video transmission optimized on DJI Flip to avoid interference and signal loss: The DJI Flip features an advanced video transmission system that enables a stable connection between the drone and the remote controller. However, in environments with electromagnetic interference, it is important to optimize the signal to avoid interruptions in transmission.
To improve signal quality, the operator should fly in open areas away from antennas, Wi-Fi networks, or metal structures that may cause interference. It is also recommended to maintain a clear line of sight between the drone and the remote controller, avoiding obstructions such as buildings or dense trees.
In the DJI Fly app, it is possible to select less congested transmission channels to improve video stability. In the event of momentary signal loss, DJI Flip will automatically activate Return to Home to prevent the drone from going out of control.
Thanks to its high-resolution, low-latency transmission technology, DJI Flip ensures a smooth, uninterrupted flight experience. Properly adjusting your streaming settings can maximize video quality and reduce the risk of unexpected disconnections.
