How do I adjust the auto-braking settings on DJI Flip to avoid collisions?
How do I adjust the auto-braking settings on DJI Flip to avoid collisions: The DJI Flip features an auto-braking system that allows the drone to stop immediately if it detects an obstacle in its path. Adjusting this setting is essential to improve flight safety and reduce the risk of collisions in complex environments.
To modify the auto-braking sensitivity, the operator must access the DJI Fly app and select the "Obstacle Avoidance Sensitivity" option. Depending on the level set, the drone will react more quickly or more gradually to the presence of an object in its path.
This system is especially useful in urban flights or in areas with many elements, such as trees, buildings or tall structures. If the drone detects a nearby obstacle, it will reduce its speed or stop completely, allowing the operator to assess the situation before continuing the flight.
Thanks to its combination of proximity sensors and artificial intelligence algorithms, the DJI Flip can predict potential collisions and take preventive measures before they occur. Adjusting these settings according to the flight environment can improve safety and control accuracy.
