How do I set the maximum flight distance on DJI Flip to ensure operational safety?
How do I set the maximum flight distance on DJI Flip to ensure operational safety: The DJI Flip allows you to set a flight distance limit to prevent the drone from straying too far from the operator or entering restricted areas. Setting this option is critical to complying with flight regulations and ensuring safety on every mission.
To adjust the maximum flight distance, the operator must access the DJI Fly app and set a specific value within the range allowed by the drone. Once set, the DJI Flip will not be able to fly beyond this limit, helping to prevent signal loss and reduce the risk of accidents.
This feature is especially useful for novice pilots who want to prevent the drone from straying outside their field of view. It is also recommended for flights near areas with airspace restrictions, where maintaining strict distance control is crucial to avoid violations.
Thanks to its smart geofencing system, the DJI Flip alerts the operator if they try to exceed the set limit and makes automatic adjustments to stay within the permitted area. Correctly setting this option ensures a safe and controlled flight at all times.
