How do I set up indoor flight mode on DJI Flip and what precautions should I take?
How do I set up indoor flight mode on DJI Flip and what precautions should I take: DJI Flip's indoor flight mode is designed to operate in closed spaces where there is no GPS signal, using vision and ultrasonic sensors to maintain stability. This mode is ideal for indoor filming, technical inspections, and flights in controlled environments.
To activate indoor flight mode, the operator must access the settings in the DJI Fly app and ensure that the vision sensors are enabled. It is recommended to fly at low speed and avoid sudden maneuvers to reduce the risk of collisions with walls or nearby objects.
Due to the lack of GPS signal indoors, DJI Flip relies entirely on its sensors to stabilize itself. Therefore, it is important to ensure that the lighting is adequate and that the ground is textured so that the sensors can properly detect the surface. In dark environments or with reflective surfaces, the drone may have difficulty maintaining its position.
Thanks to its advanced sensing and stabilization system, DJI Flip can fly accurately indoors as long as conditions are optimal. Following safety recommendations and adjusting the appropriate parameters can maximize the drone's performance in these environments.
