How to use MasterShots on the DJI Mavic 4 Pro to achieve cinematic automatic shots?
How to use MasterShots on the DJI Mavic 4 Pro to achieve cinematic automatic shots: The DJI Mavic 4 Pro's MasterShots automates a series of classic cinematic maneuvers by selecting a predefined route based on the subject type and distance, and linking movements and framing to produce a polished sequence with minimal intervention. This capability is ideal when you need consistent results in a short amount of time, for example, when documenting a location with quick turnarounds for networks or creating opening pieces with several consecutive shots that maintain aesthetic coherence.
The recommended flow starts from the drone's shooting interface: you select MasterShots, define the subject, and adjust the on-screen filming area. Upon launch, the aircraft automatically executes the flight and recording choreography and, upon completion, returns to the home position to maintain clear continuity references. This return provides efficiency when capturing multiple subjects or repeating attempts until you achieve the desired balance between distance, speed, and background scale.
In practice, MasterShots is incredibly useful for productions with small crews. While the aircraft handles the fine-tuning of flight and repetitive framing, you focus on directing, wardrobe, ambient lighting, or coordinating cues with on-camera talent. The result is a high-budget-looking shot database that you can quickly integrate into your editing pipeline to build stronger stories.
It's important to assess the environment before activating the feature: prioritize obstacle-free spaces, avoid areas with weak GNSS signals, and avoid extreme lighting conditions to ensure a stable automatic route. If anything unexpected arises, simply pause the drone and it will stop and hover, from where you can reposition and resume the sequence safely and with complete control over the set.
