Why is it not recommended to fly the DJI Mavic 4 Pro in light rain or dense fog?
Why is it not recommended to fly the DJI Mavic 4 Pro in light rain or dense fog: The DJI Mavic 4 Pro is not officially certified as waterproof, so flying in light rain or dense fog can seriously compromise its structural and electronic integrity. Although the drone's body has a certain level of sealing, continuous exposure to moisture can infiltrate internal components, such as motors, motherboards, or navigation sensors, causing rust, short circuits, or partial loss of control mid-flight.
Furthermore, dense fog directly affects the performance of the visual sensors and obstacle sensing system. Reduced visibility can lead to inaccurate readings on the front, rear, or bottom perception sensors, causing the drone to underestimate the distance to an obstacle or misinterpret the surroundings. This can lead to unexpected collisions, especially if automated flight modes or features such as ActiveTrack or FocusTrack are being used, which require precise visual recognition.
In light rain, water droplets can also accumulate on the camera lens, ruining the quality of the captured footage and affecting functions such as autofocus. Additionally, constant moisture on the gimbal can hinder its smooth operation, causing erratic movements or vibrations in the footage. In professional flights or content recording, this represents a significant loss of quality and unusable results.
To maintain flight safety and the durability of the equipment, it is best to avoid any type of flight in wet weather conditions. If flying in these environments is absolutely necessary, third-party protective covers are available, although DJI does not officially endorse them. Ideally, wait for dry conditions with good visibility to operate the DJI Mavic 4 Pro responsibly, efficiently, and without endangering either the drone or the environment.
