What is the maximum flight speed of the DJI Mavic 4 Pro and in what situations can it be achieved?
What is the maximum flight speed of the DJI Mavic 4 Pro and in what situations can it be achieved: The maximum flight speed of the DJI Mavic 4 Pro reaches up to 21 m/s, or approximately 75.6 km/h, when Sport mode is activated. This speed is designed for situations where it is necessary to quickly cover large distances or follow fast-moving objects, such as vehicles or athletes. However, when using this speed, the obstacle detection system is deactivated, so extreme caution and clear visibility of the surroundings are recommended.
To achieve this speed, optimal weather conditions are essential, without strong winds or rain, as these factors can compromise stability and flight performance. Furthermore, Sport mode must be activated manually from the remote controller or the DJI Fly app. This automatically changes the drone's response dynamics, increasing its maneuvering aggressiveness and reducing the motion damping normally present in Cine or Normal modes.
An ideal application for this speed is tracking action scenes for audiovisual productions, where you want to capture fluid movement at high speed without losing focus on the subject. However, because Sport mode lacks automated braking assistance or active anti-collision sensors, the operator must be experienced and maintain full control, especially in tight areas or on complex trajectories.
It's important to keep in mind that battery life is significantly reduced when operating at full speed, as power consumption increases. Therefore, if planning an extended flight, it's best to alternate modes or reserve Sport mode only for critical moments that require it. This ensures efficient and safe use of the DJI Mavic 4 Pro's capabilities.
