What type of microSD card is compatible with the DJI Mavic 4 Pro for 4K or higher recording?
What type of microSD card is compatible with the DJI Mavic 4 Pro for 4K or higher recording: The DJI Mavic 4 Pro requires high-performance microSD cards to adequately handle the demands of recording in 4K and higher resolutions. Compatibility is guaranteed with UHS-I or UHS-II cards with a V30 speed rating or higher, ensuring a minimum sustained write speed of 30 MB/s. For more demanding recordings such as those in 5.1K or ProRes, using V60 or V90 cards is highly recommended, especially when filming in high-bitrate modes like H.265 or Apple ProRes.
It is critical to avoid using generic or low-speed cards, as they can cause errors during recording or interruptions in the storage of captured footage. DJI recommends reputable brands such as SanDisk Extreme, Lexar Professional, or Samsung EVO Select, as long as they meet the minimum speed specification. These cards should have a recommended capacity between 64 GB and 512 GB, ideally in exFAT format, to facilitate handling large video files.
Furthermore, the drone has internal storage, but this space is limited and is not designed to store long sessions. For this reason, it is always recommended to carry several formatted microSD cards and check their status before each flight. Regular maintenance includes formatting them on the drone itself to avoid incompatibilities and file system fragmentation.
Finally, it should be remembered that the read speed also influences the subsequent transfer process, so choosing a card with a high read speed (100 MB/s or more) facilitates quick download of footage. Having a suitable microSD card not only ensures stable recordings but also preserves the integrity of the content, preventing valuable loss after a demanding flight session.
