What type of image sensors does the DJI Mavic 4 Pro use, and how does this affect recording quality?
What type of image sensors does the DJI Mavic 4 Pro use, and how does this affect recording quality: The DJI Mavic 4 Pro features a dual camera system with 4/3" and 1/1.3" CMOS sensors, respectively, placing it at the top of the range in terms of image capture among compact drones. The 4/3" main sensor is significantly larger than that of many other consumer drones, resulting in better light gathering, less digital noise in low-light conditions, and a more natural depth of field—ideal for high-quality cinematic shots.
Thanks to this main sensor, the Mavic 4 Pro can record video in extremely high resolutions, including 5.1K at 60 fps and 4K at 120 fps, enabling both smooth slow-motion recording and incredibly detailed captures. This capability, combined with advanced color profiles like 10-bit D-Log M and HLG, delivers a wide dynamic range that preserves detail in both dark and bright areas, even in challenging lighting.
The secondary 1/1.3" sensor, integrated into the telephoto camera, provides additional versatility by allowing optical and digital zoom without sacrificing quality. This sensor is ideal for long-range shots, such as tracking moving subjects or exploring inaccessible areas without compromising flight safety. The combination of both sensors allows the pilot to capture dynamic scenes from multiple angles with a single device.
Together, the DJI Mavic 4 Pro's sensor system is designed for professional photographers and filmmakers who demand maximum visual fidelity in their productions. Whether in intense natural light, sunrises, or low-contrast environments such as forests or clouds, this drone delivers stunning results that approach the level of professional cinema cameras, but with the advantage of a compact, ready-to-fly aerial platform.
