How does AI Terrain Follow mode on the DJI Flip optimize flight stability on uneven terrain?
How does AI Terrain Follow mode on the DJI Flip optimize flight stability on uneven terrain: The AI ​​Terrain Follow mode on the DJI Flip allows the drone to automatically adjust its altitude to maintain a constant distance from the ground while moving over uneven terrain. This feature is ideal for filming in mountains, valleys, and other environments where ground altitude varies constantly, ensuring smooth footage without sudden changes in height.
When AI Terrain Follow is activated, the DJI Flip uses vision sensors and altitude data to analyze the topography in real time. For example, if the drone is filming a cyclist descending a hillside, this mode will automatically adjust its altitude to maintain an optimal distance without manual intervention. This improves video quality and prevents unexpected movements.
This mode is also useful for inspecting agricultural land or buildings at elevated areas, where the drone needs to follow the shape of the ground without the risk of collision. By maintaining a constant height, the DJI Flip can capture more precise images without the need for constant adjustments by the operator.
Thanks to the combination of artificial intelligence and advanced sensors, AI Terrain Follow ensures stable flight on any type of surface. This feature is essential for operators looking to capture content in dynamic environments without compromising safety or video quality.
