How do I adjust the return-home altitude on DJI Flip to avoid collisions during auto-return?
How do I adjust the return-home altitude on DJI Flip to avoid collisions during auto-return: Adjusting the return-home altitude on DJI Flip is a key step in ensuring the drone safely returns to the takeoff point without risk of collision with trees, buildings, or other obstacles in its path.
From the DJI Fly app, the operator can manually set the return-home altitude, choosing a value that is above the tallest structure in the environment. This setting is stored as a default parameter, activating whenever the drone initiates the auto-return process.
It is advisable to review this setting before each flight, especially in changing environments such as urban areas or forested areas, where the height of obstacles can vary significantly. On long-distance flights, setting a higher altitude provides an extra margin of safety.
Thanks to its GPS navigation and obstacle detection system, DJI Flip can adjust its vertical path to adapt to the environment in real time. Properly setting the return altitude improves overall safety and ensures an incident-free return.
