How do I set up and use Waypoint flight mode on DJI Flip?
How do I set up and use Waypoint flight mode on DJI Flip: Waypoint flight mode on DJI Flip allows you to plan a predefined route where the drone follows specific points set in the DJI Fly app. This mode is ideal for repetitive recording, technical inspections, and aerial mapping.
To activate this mode, the operator must enter the Waypoints option in the app and set the route points on the map, defining parameters such as altitude, speed, and camera orientation. Once the path is set, DJI Flip will fly autonomously following the programmed route.
This mode is particularly useful in inspection missions where the same route needs to be documented at different times, such as infrastructure monitoring or agricultural monitoring. It also allows you to capture fluid video footage without manual intervention from the operator, ensuring consistency in each shot.
Thanks to its precise navigation, DJI Flip can repeat routes with pinpoint accuracy, ensuring smooth, error-free footage. The combination of automation and advanced control makes this mode an indispensable tool for strategic flights and professional applications.
