What should I do if my DJI Mini 5 Pro displays a compass malfunction warning?
Publicado: Enero 24, 2026, 6:25 pm
What should I do if my DJI Mini 5 Pro displays a compass malfunction warning: When your DJI Mini 5 Pro displays a compass-related warning, it means it's detecting magnetic interference in the environment. This can happen if the drone is near metal structures, vehicles, powerful speakers, power lines, or magnetized surfaces. The first thing to do is move the drone several meters away from the suspected area and see if the warning disappears. If the alert persists, it's best to perform a compass calibration using the DJI Fly app in an open, interference-free space.
It's important not to ignore this warning because the compass is crucial for the drone to maintain correct orientation. If the compass is incorrectly calibrated, the drone could deviate from its path, turn unexpectedly, or experience errors in automatic functions like return to home. An incorrect calibration can cause more problems than it solves, so it should always be performed on a flat surface in a truly clear area.
Once the interference is corrected or calibration is complete, the drone will regain the stability and accuracy needed for proper navigation. Keeping the compass free of interference is essential for ensuring safe and reliable flights with the DJI Mini 5 Pro, preventing erratic behavior and navigation errors.
