What advantages does the DJI Mavic 4 Pro's Advanced RTH mode offer over traditional return?
Publicado: Septiembre 6, 2025, 11:04 am
What advantages does the DJI Mavic 4 Pro's Advanced RTH mode offer over traditional return: The DJI Mavic 4 Pro's Advanced RTH mode provides a safer and more efficient return to home compared to the traditional return system. While basic return is limited to rising to a predefined height and returning in a straight line, Advanced RTH analyzes the environment in real time and calculates the most optimal route to avoid obstacles, reduce battery consumption, and ensure a faster flight.
The aircraft uses its obstacle sensing system along with multi-band GNSS positioning to identify safer trajectories. Instead of always flying at the set height, it dynamically adjusts altitude and direction, allowing it to avoid buildings, trees, or other objects on the return journey. This reduces risks in urban or forested environments, where a straight return could be dangerous.
Another benefit of Advanced RTH is power optimization. By calculating the shortest and safest route, the drone saves battery life, which is critical when a low-power warning automatically triggers return. This translates into a greater safety margin and a lower likelihood of the drone running out of battery before completing the flight.
In short, Advanced RTH boosts pilot confidence by providing an intelligent return flight that not only seeks efficiency but also safety. This difference is crucial in professional flights, where the value of the equipment and recorded footage requires superior protection systems.
