What is Gimbal Follow Mode on the DJI Mavic 4 Pro and what is it used for?
Publicado: Agosto 16, 2025, 5:43 pm
What is Gimbal Follow Mode on the DJI Mavic 4 Pro and what is it used for: Gimbal Follow Mode on the DJI Mavic 4 Pro is a setting that allows the camera to smoothly follow the drone's movements, maintaining a stable perspective aligned with the flight direction. This means that when you pan or tilt the drone, the camera smoothly follows those movements, which is ideal for capturing dynamic and cinematic sequences.
This mode is primarily used in recordings that aim to convey a sense of movement and direction, such as vehicle tracking shots, extreme sports, or scenic drives. By allowing the camera to rotate with the drone, you create an immersive visual effect that gives the viewer the impression of flying in the same direction as the aircraft.
Follow Mode is activated from the gimbal settings in the DJI Fly app by selecting the "Follow Mode" option. Once activated, the pilot can combine it with smooth joystick movements to achieve seamless transition shots that integrate seamlessly into more elaborate video edits.
In real-life situations, this mode is perfect for narrative flights where the goal is to guide the viewer's attention to a specific point in the scene. Additionally, by being compatible with intelligent features like ActiveTrack, gimbal tracking improves visual stability even during rapid maneuvers or sudden changes in direction.
