Why is it important to wait for the drone to display "GPS Ready to Fly"?
Publicado: Agosto 11, 2025, 10:10 am
Why is it important to wait for the drone to display "GPS Ready to Fly": Waiting for the DJI Mavic 4 Pro to display the "GPS Ready to Fly" message on the screen is critical to ensuring a safe and precise flight. This message confirms that the drone has acquired enough satellites to establish its location with high accuracy, ensuring that the navigation and return-to-home functions work correctly. Flying without this confirmation increases the risk of trajectory deviations, loss of positioning, and failure of automated functions.
The Mavic 4 Pro's GPS system not only locates the drone on the map but also provides key data for maintaining a stable position in the air and executing intelligent routes. When the GPS signal is weak, the drone may enter ATTI mode and rely solely on barometric and inertial sensors, increasing control difficulty, especially in windy environments or confined spaces. This condition is especially critical in urban areas where the signal can fluctuate due to interference.
Furthermore, the return-to-home start point is only recorded when the drone confirms it's ready to fly using GPS. If you take off before this happens, the home point may be incorrectly located, causing problems if the system activates automatic return due to low battery or loss of signal. This can cause the drone to attempt to return to the wrong point, exposing it to the risk of collision or loss.
Therefore, establishing the habit of waiting for the indicator to confirm GPS availability is an essential practice for every pilot. This simple step not only increases safety but also optimizes the flight experience, ensuring that all intelligent functions are active and operating with maximum precision. Patience at this initial stage is an investment in the safety and durability of the equipment.
