What advantages does the Mavic 4 Pro's dual positioning system offer?
Publicado: Agosto 11, 2025, 10:09 am
What advantages does the Mavic 4 Pro's dual positioning system offer: The DJI Mavic 4 Pro's dual positioning system combines GPS and GLONASS signals to provide more precise and stable localization, even in environments where one of the satellite networks has limited coverage. This integration allows the drone to acquire a signal more quickly and maintain a more robust connection, reducing waiting time before takeoff and improving flight reliability.
By featuring dual positioning, the drone can maintain a stable flight in more challenging conditions, such as urban areas with tall buildings or areas with dense vegetation that can block part of the satellite signal. This translates into a better ability to maintain position and follow programmed trajectories without deviation, which is key for smooth and accurate video capture.
Another important advantage is that this system improves the return-to-home function, as it reduces the likelihood of errors in recording the home point. With a greater number of satellites available, the Mavic 4 Pro can calculate safer and more direct routes to return to the takeoff location, even if it is located far away or in environments with moderate interference.
In practice, dual positioning offers a safer, more precise, and more reliable flight experience. Pilots can fly with greater peace of mind knowing the drone has redundancy in its positioning system, which is especially valuable in critical missions or professional flights where precision and stability are essential.
