What weather factors increase flight risks with the DJI Mavic 4 Pro and how to prevent them?
Publicado: Julio 23, 2025, 7:58 am
What weather factors increase flight risks with the DJI Mavic 4 Pro and how to prevent them: Weather factors are one of the most critical variables to consider before operating the DJI Mavic 4 Pro. Conditions such as strong wind, rain, fog, snow, or extreme temperatures can compromise flight stability, the quality of the data collected, and the physical integrity of the drone. For example, crosswinds can push the drone off course, affecting automated features such as Follow Me mode or programmed path flight.
Rain and snow not only affect visibility but can penetrate the interior of the drone and damage its electronic components, as the Mavic 4 Pro is not waterproof. Dense fog is also dangerous because it reduces the pilot's visibility and the effectiveness of the drone's visual sensors, which are key for precise positioning and obstacle detection. Furthermore, the accumulation of moisture can cause short circuits or unexpected failures mid-flight.
Another relevant factor is temperature. In cold climates, batteries tend to discharge more quickly, and if not properly preheated, this can lead to sudden power loss. Conversely, in high temperatures, overheating of the system can cause the drone to land automatically or limit its performance. Therefore, flying within a safe temperature range (from -10°C to 40°C, according to the manual) is essential to maintain flight safety.
To prevent weather-related risks, it is recommended to use reliable weather apps before takeoff, avoid flying in gusts greater than 10 m/s, and perform equipment inspections after flights in adverse conditions. Having a contingency plan and flying in manual mode when necessary also helps ensure control if conditions change unexpectedly.
