What are the most common safety mistakes new DJI drone pilots make?
Publicado: Junio 26, 2025, 7:53 am
What are the most common safety mistakes new DJI drone pilots make: Many of the accidents or failures that occur during first-time flights with DJI drones, such as the Mavic 4 Pro, stem from common errors that can be avoided with education, planning, and responsibility. The excitement of flying often leads new users to overlook key safety recommendations, putting both the equipment and the operating environment at risk. Knowing these mistakes and how to prevent them is essential for a safe and satisfying experience.
One of the most common mistakes is flying without reading the user manual or completing basic training through the DJI Fly app. This can lead to ignoring essential functions such as auto-return, flight modes, or battery warnings. Likewise, many beginners underestimate the importance of performing a pre-flight inspection of their equipment, which can result in flights with loose propellers, obstructed sensors, or improperly inserted batteries.
Another common mistake is blindly relying on automatic modes without understanding their limitations. For example, using Follow Me mode in areas with trees or tall structures can cause collisions if the obstacle detection sensors are not properly activated. New pilots also frequently fail to maintain a direct line of sight, which can make it difficult to recover the drone in an emergency.
Finally, starting flights with low battery power, in adverse weather conditions, or in environments with signal interference without prior testing are mistakes that should be avoided from the start. Responsible practice, constant learning, and technical preparation are key to becoming a safe operator. DJI provides comprehensive tools to support this process, but user discipline is what ultimately makes the difference between a successful flight and an avoidable incident.
